Add photo to Quick Post message
, by Hedami, is a great way to take advantage of Quick Actions in webOS by posting to your Twitter or Facebook accounts directly from . Without even loading up an app, it's extremely easy to write up a post and even select which accounts you want to post them to. But what if you wanted to attach a photo to the posting as well? While this is clearly available as an option if you were to open up the app first before writing up your post, there is also a little shortcut that you can use in a Just Type Quick Action post to prompt you to select a photo prior to posting.  All you need to do is start your message with "-i" before choosing to "Quick Post". This will then load up the Quick Post app with your message pre-populated and then automatically bring you to the photo picker. Once you select your photo, Quick Post will return you to your message and you can then choose to Send or Send & Exit the app.
If Quick Post is not showing as an option in Just Type, don't forget that you may need to
is available in the webOS App Catalog for $1.50 and is compatible with all webOS devices running webOS 1.4.5 or higher. However, the Just Type Quick Actions feature is only available on devices running webOS 2.0 or higher.
a2t.imgUYULSvJ2Yl8
    • By Low Grade
      many thanks in advance😃
    • By 43UR81006LJ
    • By NEIL_Auburn
      I have a COMPOSITE signal from a VCR that passes through a DENON AVR to my LG OLED at the composite connector (red, white, yellow) on the TV.
      I think it had displayed video in past use. But now it does not.  TV home shows AV1 connected.  Screen goes BLACK (hint?)  Then if yellow video plug disconnected, MSG from OS shows "NO SIGNAL CHECK INPUTS."
      I think TV thinks a signal is applied when the video cable is plugged in but somehow doesn't display the program!!!
      I have confirmed good video signal on cable direct from devices and from DENON with a portable TV!!
      So, what might be setup up wrong or failed in my OLED TV setup???
      Any help will be appreciated.
         Neil
      Powered by the α8 AI Processor, LG’s Latest QNED TVs Elevate the Home
      Entertainment Experience With Lifelike Picture Quality on Ultra-Large Screens
      SEOUL, Dec. 28, 2023 — LG Electronics (LG) announced the newest lineup of 2024 QNED and QNED Mini LED TVs, offering a wider selection of screen choices including ultra-large 98-inch with vibrant picture quality, advanced AI-powered processing technologies, extensive personalization features and sophisticated design.
      Evolving further, LG 2024 QNED TVs have developed significantly more intelligence with the α8 AI Processor, improving upon its predecessor with a 1.3-fold increase in AI performance, a 2.3-fold enhancement in graphic performance and a processing speed that is 1.6 times faster.
      Leveraging cutting-edge technology for a more refined visual representation, AI Picture Pro offers the ultimate picture quality based on deep learning. This versatile feature adeptly distinguishes faces, objects and backgrounds within a scene, enriching the texture and fine details to present images with unparalleled realism. Dynamic Tone Mapping Pro splits the picture into blocks and analyzes each in real-time to detect the darkest and brightest areas, elevating the details with precise HDR optimization to deliver three-dimensional image quality. With Personalized Picture Wizard, users can effortlessly customize the image quality by simply selecting a few preferred images from a given selection that are intelligently set up through deep learning.
      In addition to vibrant picture quality, AI Sound Pro captivates viewers with the audio excellence of virtual 9.1.2 surround sound from the TVs’ built-in speakers. For a unified audio system, WOW Orchestra seamlessly integrates the LG Sound Bar and the TV’s speakers, resulting in a mesmerizing 3D sound experience.
      Featuring LG’s Quantum Dot and NanoCell color technologies, the company’s latest QNED TVs deliver crisp and vivid picture quality for hyper-realistic viewing. With enhanced color reproduction, the authentic colors of QNED TVs heighten the visual depth for a more immersive and three-dimensional home entertainment experience.
      Achieving realistic contrast, LG QNED Mini LED TVs utilize Precision Dimming technology to improve gradations and accurate backlight control, and LG QNED TVs feature local dimming technology for vivid contrast and exceptional brightness.
      The LG QNED Mini LED TV QNED90 model features Million Grey Scale that differentiates between shades of gray and represents gradation with a 20-bit accuracy, providing immensely vibrant contrast.
      Boasting a sleek and sophisticated design with a slim profile of only 29mm, LG 2024 QNED TVs, including the QNED85 and QNED80 models, blend into any space and add a premium touch to the household. The TVs can also be mounted on the wall, providing greater flexibility for furniture and appliance arrangement.
      LG 2024 QNED TVs also elevate the home entertainment experience with versatile personalization and increased convenience. With the webOS Re:New program,* LG is offering an upgrade to the latest version of its webOS smart TV platform to give more smart TV owners the most up-to-date user experience for the next five years. This notable offer comes to LG QNED Mini LED 8K models launched in 2022 (QNED99 and QNED95 series) and will be extended to additional models in the QNED TV lineup worldwide in the future.
      By utilizing the latest LG webOS smart TV platform, users can create individual profiles to tailor the experience to their preferences. The TVs can differentiate between voices based on the user profiles and offer personalized recommendations by interpreting patterns from their comprehensive usage history.
      Furthermore, the main home UI screen of the newest version of webOS features Dynamic Q Card for fast, effortless access to its services, with customized organization into groups, such as Home Office, Home Hub, Sports and Games. To enjoy users’ favorite digital media, LG 2024 QNED TVs also support Apple AirPlay and Chromecast for enhanced convenience in connectivity and compatibility with mobile devices.
      Enhancing the user experience for individuals with diverse abilities, LG 2024 QNED TVs supplies an array of accessibility features including dedicated menu settings, sign language avatars, remote control tutorials, and guides for quick problem resolution.
      LG’s 2024 QNED TV lineup caters to customers’ diverse needs and preferences with a broad range of screen sizes, led by the ultra-large 98-inch blockbuster, a truly massive screen that will fully immerse viewers with its magnitude. The addition of the giant 98-inch model addresses the growing demand for larger TVs in the premium LCD TV market, and the extensive lineup also provides customers with multiple alternatives that will ideally suit any space, including 43, 50, 55, 65, 75 and 86-inch screens.
      “The LG 2024 LG QNED TV lineup takes the viewing experience to a whole new level with an advanced processor that enables outstanding audio-visual experiences across various screen sizes, while also providing a personalized user experience tailored to each individual’s unique lifestyle and preferences,” said Baik Seon-pill, head of the LG Home Entertainment Company’s Product Planning Division. “We remain committed to delivering an unparalleled customer experience, drawing upon our decade-long expertise with webOS.”
      CES 2024 visitors will have the opportunity to explore LG’s most recent innovations and technologies in home entertainment experiences at the company’s booth (#16008, Las Vegas Convention Center) from January 9-12. To keep up with all of LG’s exciting announcements at CES by following #LGCES2024 on social media.
      * Pop-up notifications offering a full upgrade without the need to select specific UX, UI or features are only sent to customers who have agreed to receive them. Please note that this upgrade does not cover the TV’s hardware performance, features or durability.
    • By Huig
      I have a UJ701V tv from 2017. I get a random disturbance of the sound and picture and then the tv reboots. I have already removed the back cover and everything looks fine. According the logfile i have to replace the mainboard but i think the problem will stay.
