LGE6 TV settings menu won’t open. Any settings just say loading when you click on them. I.e. picture mode, aspect ratio, and all settings
this TV has done this before but it somehow fixed itself after a month. I’m wondering if anybody knows how to correct this problem with the settings menus stuck on loading.
    • By David Daul
    • By Maggie
      The replacement remote for our lg tv (65uq7070zue) stopped working yesterday while i have kids home on winter break. I ordered a voice magic but even though i checked the specs several times and made sure the model number was specifically mentioned it won't pair and lg says it's the wrong remote. I stupidly reset the tv during this not thinking that it would totally unpair the tv from my phone remote app and it's now stuck on press the wheel/ok screen. I've ordered a lg brand remote but it'll be a couple days and it was supposed to be our movie day. Is there any way to switch the hdmi with it stuck on this screen so we can use the fire stick or playstation? Two universal remotes, one specific to lg tvs, have failed to accomplish anything as well.
    • By Cody94549
    • By victoranthony
      Hey everyone,
      I have had LG TV for just two years. Last weekend, when I turned it on, it showed a blank white screen but was still illuminated, with sound working. No LG logo or image appeared. I unplugged the TV and held the power button for 30 seconds while it was unplugged, and the screen issue fixed the issue for a week[url=https://whitescreen.vip/
      ].[/url]
      However, the same white screen problem has now returned, and the power reset trick no longer works.
      Should I contact a local TV repair technician or reach out to LG customer support first?  Any advice?
    • By Low Grade
      many thanks in advance😃
