App Review: MeOrg! for SpringPad
Ever since the TouchPad was released people have been looking for a solution to their Evernote woes, what with the fact that Evernote never created an app for the TouchPad and more recently that the app for phones was broken by a change on the Evernote servers. In swoops
, a SpringPad client made by Sven Ziegler. SpringPad is a service not dissimilar to Evernote in that they both pretty much do the same thing, with many even preferring SpringPad over Evernote, but can MeOrg! stand up to the task?
a2t.imgCqr-DAh76sA
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
