Disney + error on my LG tv
By Pierre Vicquery
Hi, I noticed that the Disney+ app does not show HDR anymore on my TV even though I have a compatible subscription. Does anybody know why?
By Gregor Huc
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By alfie
