usb app test install apps via usb
By anna groove
By Pranay Mokida
By MNHL
By Tobin
Tobin
By Sqwazy
- 0 replies
- 4,429 views
nicovon
Good evening, I have a LG webOS UM7100PLB TV. Is it possible to install apps from usb stick? what format should the apps be in, can I find some examples of apps to install via usb?
