I cannot turn on my TV. I press the power button and it flash for three or four time and nothing happen.
I unplugged the power cord over night and tried it again and same problem.
I disconnected all the cable and turn back on and I still have issue,
Anybody has any idea on how to fix it?
My TV model number is LG 50UH5500.
Thanks.
    • By Joe C
      Since the Web OS update last week, the line on the Home Screen with all my apps has changed.  Now Apps is the first one in the line.  I do not want it there, but cannot move it.  If I go to the end where it shows Edit Apps, I can click on any app to move it or delete it.  But, the Apps icon is grayed out and cannot be moved.  My neighbor has the exact same model I do -- LG OLED 653PUA -- and it is not like that on his tv.  He can move the App icon anywhere he wants.  This is very annoying as it defaults to the Apps icon when I click on Home and then I need to click to get to YouTube TV, which until the update was always first in the line.
    • By u84six
    • By Low Grade
      hi,
    • By starwoodtech
    • By Peter Steinmeijer
      I can't connect  my LG ThinQ app to Google Home app.
      But my tv, the LG Web OS TV  UM7100PLB ( 2019 ), is in the LG ThinQ app. I even reinstalled it.
      Is my TV too old ?
