Hi all,
If u all can check, alexa on my lg c2 oled 55 inch has stopped working sometimes it gives error like its unable to connect to server and now when i give commands to play or pause any music or video, it says it can not do it.
I have reset it multiple times it does not work.
Many users on alexa app skills for lg tv webos are also talking about the same, that means its not limited to me only
    • By Rex G
    • By sudar shan
    • By NaveenKumar
    • By jcol5786
