lg TV quick settings; edit and add new item to quick settings
By Cody94549
By Low Grade
many thanks in advance😃
By Magsing
By toopie28
Hi can someone help please.
Not sure what else to try.
Thanks!
By Itachi3431
Hi all,
P.S., running latest Web OS
pattox
It is easy to add a new item to the quick settings side menu on an lg c2, as long as the item you want is shown on the list presented when you choose the + add item. If you want to add a "shortcut" to an item that is not on the list then how can that be done. Is it possible to edit the list presented?
Specifically I want to add a shortcut to "subtitles on" which is buried deep in accessibility settings, there nothing on the list of options presented to allow this.
3 answers to this question
