Restart after firmware update
By mean2
By OliverRC
By Ajothen
By Roy Brown
By atcronin
Ceapa Adrian Emil
Hi guys! I have a 55QNED81QA and my question is this:
After software update, how do i restart the webOS without unplugging the TV from outlet ? I don't see a restart option in the menu !
