WebOS Defaults to Apps Screen after Latest Update
By mean2
By OliverRC
By Ajothen
By Roy Brown
By atcronin
desart1566
I noticed since the last update of WebOS, it defaults to a screen with apps along the bottom rather than HDMI1 as before on startup. Even after going into the input settings and selecting HDMI1, it stills defaults to the other screen on startup. When selecting HDMI1 on the inputs screen, it has a red dot in the corner, which I would assumes means that's the selected default. But again, this seems to be ignored this on startup.
Thanks.
4 answers to this question
