Voice not recognised when I'm using voice recognition
By hollean
By JamieG
By Calvinder
Any suggestions
By leodavid
I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
The buttons work fine but for some reason, I can't get the cursor to appear on screen.
Appreciate the help. Thanks
By makem
I have a LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
- 3,358 views
cch4rm
Istg it worked fine 10 minutes ago.
