By Stephen Davies
By hans peter
After the latest update, I'm not happy with how the TV behaves when I turn it on.
1) When I turn off the TV with on/off on the remote control firts and after that disconnect the power, the TV starts up at newstart with the last seen program, the remote control does not work. It goes after a while into black and restarts than with this image.
2) If I turn it off instead by unplugging the power first, it boots up with last viewed program and the remote works as usual.
Is it possible to go back to the previous update or where/how can I influence what appearance my TV picture should have when I start the it? I want my TV to start (preferably) with the previous program, but in any case so that the remote control works immediately.
/hans peter
By next 0815
A satip / sat>ip / sat over ip client software or app available for a beamer with WebOS like LG Largo or the newly announced LG Andante would add significant value.
Networkcable and power thats all you Need to get acces to all chaines your satip / sat>ip / sat over ip Server provides
What is blocking to provide a little piece of Software?
By MarkMyWords69
Hi I have an OLED A2 48” 4k, which doesn’t have an aerial but is connected to WiFi. All the streaming services are working fine, but my understanding (From Freeview website) is that the TV guide should be populated with a live Freeview TV schedule that , if you click on a live broadcast, opens it up in the relevant app. E.g. BBC, ITVX, 4 etc.
There are a couple of BBC IP channels showing, which play without opening the apps but nothing else.
Any ideas?
I have the Freeview App on my phone which does exactly what I was expecting above.
By SimonW
WebOS 05.20.15
DNS over TLS active on router (Cloudfare), all apps (like Netflix, Prime Video & HBO Max etc) are working fine, but the Apple TV app times out (no network)
Removed the app, installed it again, but still not network. Turned DNS over TLS off, Apple TV works fine.
According to Apple it's a LG (WebOS) issue, the only requirements, they say, are "active internet connection" and "no VPN".
Also tested with Apple TV on a Fire TV Stick (on same network) and there it's working fine wiht DoT. Unfortunately Fire Stick is not 4K, so app on TV is preferred.
Look to me issue is with the Apple TV app itselfs, but Apple says it's LG.
Anyone got some suggestions?
Rosie
Fire TV upgraded and since then I'm unable to use my remote. I have to use the button below TV and have no freeview. Unable to get to settings to tune TV. Grateful for any advice
