Company Supplies State-of-the-art Multi VTM i System to Landmark Commercial
Project, Strengthening HVAC Leadership in Southeast Asia
SEOUL, Apr. 3, 2025 — LG Electronics (LG) has supplied its state-of-the-art Multi VTM i, a variable refrigerant flow (VRF) solution featuring an advanced AI engine, to a newly constructed 59,800-square-meters logistics center in the Singapore’s Tuas area. This milestone project underscores LG’s commitment to expanding its heating ventilation and air conditioning (HVAC) business in Southeast Asia.
To achieve the highest level of the Building and Construction Authority’s Green Mark certification program – specifically the Green Mark Platinum (Super Low Energy) rating – the logistic center required an exceptionally efficient and comprehensive HVAC solution. LG distinguished itself by presenting a tailored package that optimally meets the client’s specific needs. To further enhance the already outstanding performance and energy efficiency of the Multi V i, LG integrated its proprietary inverter compressor and a larger heat exchanger.
LG Multi V i intelligently adapts to environmental conditions, optimizing operation while minimizing unnecessary energy consumption. It incorporates LG’s industry-leading HVAC innovations, including HiPOR (High Pressure Oil Return) technology, which ensures peak efficiency during part-load operation by improving operational stability, even in challenging conditions. The heat exchanger, enlarged by over 10 percent, accelerates cooling and heating response times, while dual inverter compressors promote increased durability, energy savings and overall efficiency. Moreover, LG’s proprietary energy management tools, including real-time Coefficient of Performance monitoring, provide actionable insights to help building operators reduce HVAC energy consumption without sacrificing performance.
As Singapore strengthens its position as a key regional and global logistics hub – with transportation and storage accounting for over 10 percent of its GDP as of 2022 – the demand for energy-efficient solutions in large-scale logistics operations is steadily increasing. LG estimates that the HVAC market for logistics centers in Singapore is valued at approximately USD 25 million annually, with further growth expected in the coming years. By supplying its advanced Multi V i system, LG is well positioned to accelerate its HVAC expansion across Southeast Asia, where sustainability-focused building initiatives are gaining traction in countries such as Indonesia and Malaysia.
“Precise Development Pte Ltd is thrilled to collaborate with LG to deliver this best-in-class facility,” said Mr. Peh Chong Eng, Group CEO of Precise Development Pte Ltd. “LG’s cutting-edge technology, combined with their attention to detail and responsiveness to our needs, sets them apart from other equipment suppliers. We highly recommend LG air solutions for any project.”
“Fidecs is proud to achieve the BCA Green Mark 2021 Platinum Super Low Energy certification by integrating LG’s high-efficiency VRF system,” said Ervin Chng, Director of Business Development at Fidecs Engineering Pte Ltd. “This milestone demonstrates our commitment to sustainable building solutions and sets a new benchmark for energy efficiency in Singapore.”
“LG Multi V i exemplifies our dedication to creating innovative, energy-efficient solutions that address the changing needs of our clients,” said Jaeseung Kim, Regional CEO of LG Electronics Asia Pacific. “Aligned with Singapore’s Green Mark certification and the growing sustainability initiatives in Southeast Asia, including Indonesia and Malaysia, we are committed to pursuing HVAC opportunities tailored to the specific needs of the region.”
By Peter_T
By akhil7j
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
At Frieze London 2024, LG OLED and Akomfrah Bring Art and Technology
Together to Inspire Audiences With a Thought-Provoking Film Installation
SEOUL, Oct. 11, 2024 — LG Electronics (LG) has once again partnered with the widely respected artist and filmmaker, Sir John Akomfrah, for Frieze London 2024. This collaboration follows LG’s recent support of Akomfrah’s British Pavilion at the 60th International Art Exhibition at La Biennale di Venezia 2024. At Frieze London 2024, LG OLED has invited Akomfrah – an artist and filmmaker known for investigating themes such as memory, post-colonialism, temporality and aesthetics – to present a new video installation at the fair.
Becoming Wind (2023) is a five-channel video installation that focuses on the intersection of social and environmental issues, looking specifically at the experience of non-binary and trans actors and activists in the context of the climate crisis. A profound meditation on identity formation is framed by an allegorical representation of the Garden of Eden and its disappearance; a montage of footage evoking the abundant richness of past biodiversity is interrupted by glimpses of blazing wildfires, scenes of racial discrimination and a fragmented text, underscoring responsibilities to confront multiple and intersecting crises.
Powered by the compelling fusion of art and technology, multiple ultra-large LG OLED displays bring Akomfrah’s artistic narratives to life with stunning picture quality on an incredible scale. Notably, LG OLED’s self-lit nature reveals the full, vivid expression of the colors, enriching the depth and realism of the artwork’s multi-sensory elements for a truly immersive experience.
LG’s commitment to making LG OLED a more sustainable choice closely aligns with Akomfrah’s drive to address climate change, human communities and the plight of migrant diasporas globally. LG OLED TVs incorporate fewer components than LCD TVs due to the absence of a backlight, which results in the 65-inch OLED TV using 60 percent less plastic compared to an LCD TV of the same size. Weighing in at about 20 percent less than an LCD TV of the same screen size, OLED screens also contribute to the reduction of CO2 emissions during transit. In addition, recycled plastic accounts for approximately 20 percent of the plastic used in the manufacturing of all LG TVs, including OLED models. These efforts have culminated in LG OLED TVs receiving environmental product certifications from the UK’s Carbon Trust and Switzerland’s SGS for four consecutive years, underscoring the company’s commitment to sustainability.*
“I’m truly delighted to be able to bring my artistic vision to life with LG OLED,” said Akomfrah. “Becoming Wind aims to draw viewers into a deep state of contemplation about the intrinsic relationship between nature, humanity and technology through the interplay between sound and visuals. LG OLED’s advanced audiovisual capabilities and technological advancements enhance the sensory elements of the art, seamlessly integrating image, sound and emotion to take audiences on a visually compelling and intellectually stimulating journey.”
“We are pleased to continue our collaboration with renowned artist Sir John Akomfrah to highlight how LG OLED captivates audiences by enhancing the depth of his thought-provoking artwork,” said Kate Oh, vice president of the Brand Communication Division at LG Home Entertainment Company. “LG OLED remains committed to supporting both artists and audiences who embrace our passion for innovation and positive change. We will continue to empower artists who seek to inspire the world through the intersection of art and technology.
Visitors to Frieze London 2024 can experience Akomfrah’s artwork Becoming Wind from October 9 to 13 at The Regent’s Park. Visit the
link hidden, please login to view to step into a world of artistic brilliance and explore captivating collaborations with LG OLED ART. # # #
* Carbon Trust: Carbon Footprint Reducing certifications (2024 LG OLED evo G4 77”/65”/55”)
Carbon Footprint Measured certifications (2024 LG OLED evo G4 97”/83”, C4)
SGS: Environmentally Evaluated certifications (2024 LG OLED evo G4/C4/B4)
- 5 replies
- 3,552 views
- 1,212 views
- 1 reply
- 1,982 views
- 1,465 views
