Hello
Every week ( or so ) I get this ( see photo ) on my TV.
I can click it away, but, as I said, it keeps coming back.
This doesn't seem to affect my TV, but it is annoying.
I don't know if any action on my part is required but if not how do I stop it from reappearing ?
thanks
Peter
 (  [LG} webOS TV UM7100PLB  )
    • By u84six
    • By bos2prov
    • By Birkso
      Have an LG55Nano which works well apart from when on specific BBC shows whereby whenever there is a switch if camera, say from contestants to host and vice versa, there is an extremely annoying flickering motion that takes place. May sound petty but any visitors comment on how distracting it can be.
      Happens constantly on Richard Osmans House of Games, Impossible, Pointless and similar BBC programmes. Reported it but was told I had to get video clips for them to assist despite it being less than a year old. Life's too short. Any advice very welcome.
    • By Julio Henrique Morimoto
      I've had an LG 47LB6500 for about five months now. I love the TV and it's great. Except one thing that I find irritating is a constant AV input popup that keeps reappearing over, and over, and over.
      While watching any content from any input, the popup appears.
      link hidden, please login to view.
      The only device plugged to the TV is an HDMI Sky HDTV Set Top Box, and there is nothing plugged into any AV input. WebOS seems to enter some variable loop, displaying several of these popups in sequence. Often, the number of popups is such, that the TV will freeze trying to show all of them. I can only assume a lot of its CPU is being used to render them. The TV will become unresponsive until all popups disappear. The annoyance may last a couple of minutes, but it happens everytime the TV is turned back on.
      From the input configuration screen, I can see the AV input is active. .
      Once it's removed, the popups are gone. But once the TV is turned off and back on, WebOS will scan for devices and these empty AV inputs are back on the list... and the parade of popups will follow.
      As a user, I have to consder this a bug. And it's a very irritating one. These popups cover subtitles and seem to show up minutes after the TV is turned on. Please provide a fix with a firmware update or, at least, provide a workaround to make it stop.
      Kind regards!
      Julio
    • By leimberger
      While watching YouTube on my WebOS TV, I very frequently pause the picture and I do not like the picture dimming the second i hit pause.  It makes an extremely unpleasant experience when the remote requires 6 actions to go from 'pause' to 'play'.
      Step 1) push 'pause'  (screen goes dim)
      Step 2) 'up arrow' (to get rid of dimming)
      Step 3) 'up arrow' a second time (to finish getting rid of dimming)
      Step 4) push  'play' (screen goes dim)
      Steps 5 +6) repeat steps 2+3  (screen is now bright and playing)
      6 steps?   2 steps is the ONLY logical number.   1) pause and  2) play (actually just pause for both pausing and play but we'll leave that for now)  6 steps makes  for a VERY unpleasant viewing experience.
      Yes I am aware the screen will return after about 3 seconds.  (unpleasant/frustrating)
      Yes I am aware that I can use the 180 degree arrow key to reduce the number of steps to only 4.  There are 2 problems with this method.  1) Its still 2 steps too many.  2)  If i wait a split second too long, the screen will return to bright screen at the same moment I push the button and now that 180 degree arrow button is programmed to return you to the main menu.  This makes it even more aggravating because I now have to go into the history menu to restart the video.
      Can someone please tell me how to eliminate the auto dimming?  If its not possible, can the webOS programmers just reprogram the system to stop doing this.  Yes, its a first world problem, but when you hit 'pause' as much as i do,  honestly want to return the TV.  I can't take how poorly it was designed.  It makes no sense.  thank you for your help.
