Cannot open settings or streaming apps
By Andreas Boyatzoglou
Model: OLED55BX3LB
Viewing videos from
link hidden, please login to view was fine up to about one month ago. I do not know if there was an upgrade, but videos from that site cannot be played any longer on this tv. From the same wifi network (home network) videos from that site play fine to a number of devices (Android phones, 2 win11 laptops, 1 win10 laptop).
By Justin Bester
By NickL
Br,
Nick
By thewookiewon
By Joe C
LG user1
I can't open settings on my LG B9 55" either from the remote (results in black screen) or from menu system (same). Also, when I click on any streaming app, nothing happens although the buttons on the remote otherwise work. I would like to try a factory reset, but can't do this without accessing the system menu. If you know how to factory reset without the menu or otherwise know a fix, please let me know!
