LG UHD 4K TV reboots when being used as a monitor and watching videos
By George Johnson
Recently when I view an MP4 in a 4.3 format, the picture is being stretched to fill the screen thereby distorting the picture by making it wide. The setting is at original, and in a input MP4 video mode, there is only one selection (original). So I assume that the 4.3 will show up as 4.3 with black bars on both sides, but nope.... How do I turn off the stretch feature? My unit is a OLED65C9PUA and my PM4's are on an external drive plugged into the USB port.
By benwten
I set recordings or reminders from either search or TV guide.
Then when I look at the scheduler I see that they are listed.
The problem is that maybe later in the day, or on the following day, when I check the scheduler to see if my planned recordings are there, I either see some are missing or the whole lot have disappeared.
To be clear: I mean they disappear before the event happens.
This I have investigated after recordings failed to happen. I have not retuned or reassigned program channels etc or changed any settings or anything like that.
Why does this happen?
I swear this used to work when TV was new.
Is there a bug with my firmware version?
Fw version: 05.50.10
TV: 43uk6750pld
Hard drive: Maxtor onetouch III mini 80gb
By Kieran Bryons
I'm looking to buy an LG AI Thin Q TV, how do the sports alerts work -
link hidden, please login to view I literally watch loads of sports, does it update you on only certain sports or all sports?
By RobLGSucks
I have an LG OLED55B7A that has been rebooting randomly ever since I updated it to webOS 6.00.05 about 6 months ago. I have noted there is a new webOS version 6.00.20 available. Has anyone here had the same rebooting problem, and if so, did the latest webOS correct the issue?
In general, my setup has the LG tv doing as little as possible - it is simply a display for my Roku box via my AVR, as the TV's interface and apps slowly became completely unusable about a year after purchase. So, no ethernet, no WiFi, all services turned off, etc., and this helped with all of the performance issues, except the rebooting.
@ LG : if you ever read this - you have done a TERRIBLE job of managing the software on these TVs. webOS started off as a real alternative to all of the external set top boxes, but now, I will *never* *ever* buy another LG TV again, and I tell everyone I know to avoid them. Worst product management in the consumer electronics industry in the past 10 years.
Thanks fellow sufferers for any tips.
Rob
By Bobs Reviews
I watch a conservative news channel, channel 138, newsmax, and in the middle of a story commercials pop up and interrupt the story.
I've turned off LG channels plus, and add customization, and that has done no good. I canceled my cable, and signed up with Hulu to avoid the commercials. Now on top of regular TV commercials LG inserts its own garbage.
I also understand Samsung, and Sony are doing the same thing. My assumption is whoever the IPTV provider is, they are the ones inserting the commercials, and the major TV brands use the same service for all of the TV brands.
This is unacceptable. My future plan is to not buy one of these major branded TVs. It's not bad enough that we are inundated with commercials on cable, and network TV, now there are inserting commercials on an IP stream.
Disgruntled TV owner, thanks for listening.
