IW Pro PrefsImage Worker Pro, by MetaViewSoft, is an app that will allow you to edit your photos directly on your webOS device, giving you the ability to resize, crop, rotate, adjust brightness, and so much more (check out our
, although note that MetaView is actively updating the app and there may have numerous enhancements and bug fixes since our review). One of the updates to the app has been to change its rotation so that it's always in a landscape mode. While this works better on the TouchPad, you may prefer the app to work in a portrait orientation on a webOS phone. Although there is no preference within the app itself to change the rotation, MetaView added a homebrew solution for you to manually adjust it. The easiest way to do this is by using the text editor within the homebrew file manager app Internalz Pro and following the directions below:
  1. Close Image Worker Pro, if opened
  2. Open up Internalz Pro and navigate to /media/cryptofs/apps/usr/palm/applications/de.metaviewsoft.printimagepro/
  3. Find the prefs.txt file, tap on it, and select "Open" to open up the text editor.
  4. Towards the bottom of the file, find the row that says "ORIENT=".
  5. Update the row to say "ORIENT=1"
  6. from the top-left to reveal the Application dropdown menu and select "Save File".
  7. Close the file
  8. Next time you open the app, it will now be in portrait mode
Note that you may need to make this change every time MetaView updates the app (which is rather often).
is available in the webOS App Catalog for $1.99 and is compatible with all webOS devices running webOS 1.4.5 or higher
a2t.img6f2vabjYwdw
      Key Specifications:
    • By William Quay
      We have a new 32” LG tv. The picture is great. Sound is great. Controls are confusing to us.
      when using DVDs the resolution seems fine. But when cable tv is on the image overflows the screen, cutting off parts of the picture.
      we can’t figure out how to fix. Probably simple, but we can’t find it.
      Help?
      The Company’s First Diagnostic Monitor With IPS Black Technology,
      Features an 8-Megapixel Resolution and a 2,000:1 Contrast Ratio
      SEOUL, May 30, 2023 — LG Electronics (LG) has launched its 31.5-inch IPS Black diagnostic monitor (model 32HQ713D). The company’s first medical monitor to employ IPS Black technology, the new model provides sharp, clear images with vibrant colors and a 2,000:1 contrast ratio. LG’s new diagnostic monitor delivers consistent image quality via automatic self-calibration and ease-of-use with 6 convenient hotkeys.
      Thanks to an 8-megapixel resolution (3,840 x 2,160 pixels), LG’s IPS Black diagnostic monitor offers the level of clarity needed for medical imaging, including x-rays, mammograms and CT scans. With Multi-Resolution Mode (8, 6 and 4MP), users can adjust screen resolution to suit the type of image being viewed.
      Equipped with IPS Black technology, the 32HQ713D provides clear image definition with deep blacks and detailed expression in the low gray tones. LG’s diagnostic monitor also features a built-in front calibration sensor that enables automatic self-calibration to help keep image quality stable.
      Additionally, the 32HQ713D comes with Focus View Mode and Pathology Mode. Controllable with either mouse or keyboard, Focus View Mode makes it possible to select a specific part of an image to review – dimming the rest of the screen to help highlight the area of concern. Pathology Mode provides image clarity and accuracy as if looking at a microscope.
      LG’s new diagnostic monitor offers a convenient user experience with 6 hotkeys that make it quick and simple to adjust various settings, including mode, screen resolution and lighting. For convenient management, the Presence Sensor automatically turns the display off after 5 minutes if no motion has been detected. The monitor also comes with a one-click stand that simplifies the installation process and offers ergonomic comfort with adjustable tilt, height and swivel.
      “LG’s new diagnostic monitor offers the high contrast needed for displaying clear medical imaging,” said Silas Choi, vice president and head of the B2B solution business division of LG Electronics Business Solutions Company. “Leveraging our outstanding display technology, we will continue to provide medical monitors that meet the specific needs of medical professionals.”
      The 32HQ713D is now available worldwide. For more information about LG’s diagnostic monitors, visit
      link hidden, please login to view. Key Specifications:
      LG Diagnostic Monitor (32HQ713D)
      Panel Panel Type IPS Black Inch 31.5-inch Aspect Ratio 16:9 Resolution 8MP (3840 x 2160) Color Gamut (Typ.) sRGB (CIE 1931) 100 % Brightness (Typ.) 1000cd/m² Contrast Ratio (Typ.) 2000:1 Response Time (Gray-To-Gray)
      14ms (GtG, Overdrive Not Supported) Feature DICOM Compliant Yes Hardware Calibration Yes (Software Application: LG PerfectLum)
      Display Mode Multi-resolution Mode (8/6/4MP), Focus View Mode, Light Box Mode, Pathology Mode Video Signals Input Terminals DisplayPort x2 User
      Convenience PBP / Dual Controller Yes (2 PBP) / Yes Lighting Yes Hot Key Yes (6 keys) Presence Sensor Yes Physical Specifications
      Adjustable Stand Swivel: ±15° / Tilt.: -5°~15° / Height Range: 110mm * Product specifications may vary by region and are subject to change without notice.
    • By ROBROY
      How can I flip camera image left to right?
      (Using LG Compatible Logitech c920 webcam however image is mirrored. )
