Will there ever be a fix to Smart Share's library refresh issue?
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
t1m
In reference to the following post
I mean really, 9 years later and still no fix? Only way to actually update your library is to re add the folder your media is in. Any possibility of a fix ever?
