Apps such as iPlayer, Netflix and Prime either won't load on my LG TV or cut out within half an hour. The apps say that the TV isn't connected to the internet. I've checked the leads, tried unplugging the TV and turning it back on, replaced the cable, reset the router and reset the TV. Nothing has worked. Can someone suggest a solution?
You can post now and register later.
If you have an account, sign in now to post with your account.
Duncan McKenzie
