No option to have an installed app (such as Google TV) set as default at start up instead of LGTV channels or an input
I have been in hi end AV technology for years and I have purchased a ThinQ "smart" TV. After finally finding a way to stop the ridiculous loud static start up now I want to find a way to have the TV start at an installed app (Google TV etc.) instead of the unused antenna or HDMI input. It seem this would be the default if not just an option on a smart TV when actually using installed apps. Have I been missing something or is this some bizarre epic fail?
3 answers to this question
    • By garamja
    • By Michael Hirons
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By Cody LUEN
      Hi!
      Version: 23.20.36
    • By coltaz
