HDMI ARC NOT WORKED WITH ANOTHER HDMI
Good Morning,
I have a TV LG webOS UN71006LB and a Bose Tv speaker soundbar.
HDMI ARC doesn't work when another HDMI(for example Playstation4) is connected.
Can you help me, please
    • By Venkata
      Hello Team,
    • By OliverRC
    • By hollean
    • By Kane Murphy
    • By starwoodtech
