Password Manager NEEDED!
By agus
By MinoDc
Hi to all.
What do you think
By Batman
I have a LG 43QNED756RA AEK Smart TV
If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
So I cannot Move or Edit Program Numbers or Delete
Any help and comments would be appreciated
By Francisco Estrada
I have the LG WP401 webOS Box model, to configure it, the previous administrator gave it a password and it did not leave it for me.
How can I give it a factory reset or change the current password to be able to enter via the Web, to use the content manager and control manager
Thanks for the help
By CpRivers
I am looking for an app that will allow me to play videos from a shared folder on another computer, something like VLC. Is there an app for the LG to do this? I haven't been able to find anything. I set up the Media Center on the other computer but it doesn't work right and can't see all the available videos. I just want to be able to browse a shared folder.
Chuck
