On Screen Pointer Has Disappeared
Hi Folks, I recently bought an LG 65C3 OLED. When first set up, the on screen pointer was visible, now it has disappeared. Under setings>pointer options are grayed out (deactivated). Is there a way to recover it short of resetting everything to the default state? Thanks
    • By crct
    • By DWINKS49
    • By Batman
    • By u84six
