Is there a setting to override the keyboard character layout?
By Will M
By joe zx
I have LG oled 55b8pla, it is connected to the net, it has the latest update installed, when I start the web browser application and in the on-screen keyboard I start typing for example the URL of the web page, so instead of the number 1 it displays a number 2, instead of the number 2 a completely different character, etc. etc. etc.
I turned the TV on/off, turned the app on/off, unregistered the remote and registered it again. No effect so far.
Any advice, thanks.
By netsplit
By Stuart GIBSON
I have a 48" OLED (Model: OLED48A26LA). after updating to software version 13.30.61 the Sky New Live feed just displays "There was a problem with this video [timeout]". It worked perfectly before the TV software upgrade.
Ive reinstalled the Sky News app but still doesnt work. wifi etc is all ok.
Any ideas?
Stuart
Ian_AW
G'day,
Many apps will bring up an alphabetised layout of keys rather than the more conventional QWERTY keyboard.
Is there a way of overriding this so that a conventional QWERTY layout can be used?
Thanks.
