ares-install ERR! [com.webos.appInstallService failure]: luna-send command failed <update manifest file failed>
I was unable to install the remote control app(on TV) after bundling with Sandstorm webdriver code. Getting below error. ares-install ERR! [com.webos.appInstallService failure]: luna-send command failed <update manifest file failed>
    • By Glen
      Appears that my main audio amp has failed, no audio from TV speakers.
      The pre-amp is okay since I plugged in sound bars, wireless headsets, and optical connection all ok.
      The repair would cost around $300 so I decided it was cheaper to buy a soundbar.
      Anyone else experience this problem, ie no sound from the TV speaker?
    • By philotas
      I followed these steps to prepare my LG TV and it all worked fine:
      However I cannot push IPK to tv or just list stuff:
      I am getting this error when calling:
      ares-device-info --device tv2 outputs:
      ares-device-info ERR! [syscall failure]: read ENOTCONN Any ideas?
      I can ping the TV just fine and getting the key from the TV also worked but connection fail...
      I am using macOS 12.16 and the TV is using webOS 4.9...
      I also tried different node versions (v8.17.0 and v17.3.0)
      Any ideas?
    • By coyote
      I've got my ThinQ and Google Home apps and Google Home speakers set up to turn off my LG C1.  But they won't turn it on, I guess because the TV isn't listening for commands when off.   I expected that enabling these Settings|General|Devices|TV Management|Quick Start+ Settings|General|Devices|External Devices|TV On With Mobile|Turn on via Wi-Fi would do it, but it did not.
      OMG I just discovered that Alexa turns on the TV...and I never even had to open let alone set it up in the Alexa app!
    • By John Pimento
      After I configure de IPTV Smarters data, which work in my Amazon Fire stick, it gives me the "Failed to Authorize" message. Is LG Smart tv OS compatible?
    • By vladtheodor
      How can i access Linux in Smart TV to install Synaptic for another browser/navigator and a Facebook-messenger? And other stuff...
      How can i copy/paste text in browser/navigator?
