Cannot login to LG.com.au
By Joe C
By starwoodtech
By Peter Steinmeijer
Is my TV too old ?
By Stephen Davies
By williemyers
hi all,
for a couple of years now, I've enjoyed AirPlay between my mid-2012 MacBook Pro and my LG Smart TV. But last week, I had to do a Migriation Asst./Time Machine re-install of the system drive on my MacBook Pro/Mojave. Result is that I can no longer get a connection with my LG TV. Two things:
When attempting to AirPlay connect, I now get a Mac window asking for a PIN code. Then , the LG goes black and gives me a 4-digit AirPlay code, I enter it in to the Mac, but it reports, "could not connect to LG TV" etc. 2. I've put an AirPlay icon in the menu bar, but when I click on it, I see a greyed-out "AirPlay:" that constantly switches back and forth between "AirPlay: Looking for TV..." and "AirPlay: Off"
All help/thoughts appreciated!
DeBC
I have attempted to log in to my existing LG.com.au changing my password numerous time and still can not log in.
I have even changed browsers but still not able to log in.
I am unable to log into LG app on the TV as well. I have been trying to log in since april 2023 til now Aug 2023.
