Feature Request: Boot LG WebOS TV Directly to Home Screen Instead of Wallpaper
Hey everyone, I've been using my LG WebOS TV for some time now, and there's a small but impactful change I'd love to see. Currently, when the TV is turned on without an HDMI input, it defaults to displaying a wallpaper. It's not aesthetically pleasing, it's a bit of an inconvenience for users like me who primarily use the TV's smart features.My suggestion is to include an option that allows the TV to boot directly into the Home screen, displaying all the available apps and streaming options right away. This would streamline the user experience, making it faster and easier to access the services we use most.Would love to hear the community's thoughts on this. Cheers!
  • 6 months later...
Press the mute button on your remote three times. A menu should come up that allows you to disable both the ‘no input’ pictures as well as the screensaver and the LG start up logo.
    • By atcronin
    • By DWINKS49
    • By Batman
