LG Presents Its Vision to Become Media and Entertainment Platform Company
By wallyricks
Comprehensive Suite of Innovative Heat Pumps and Chillers Highlights
Company’s Commitment to Meeting Customers’ Varied Needs
SEOUL, Feb. 10, 2025 — LG Electronics (LG) is showcasing its latest heating, ventilation and air conditioning (HVAC) solutions at the AHR Expo 2025 in Orlando, Florida, from February 10-12. Aligned with the global shift toward decarbonization and the increasing demand for electrification technologies in the HVAC market, LG’s expanded HVAC lineup offers tailored solutions for diverse commercial and residential environments. LG’s comprehensive portfolio of HVAC components, also on display at the AHR Expo, further demonstrates the company’s enduring commitment to innovation, quality and sustainability.
Visitors to the LG HVAC booth can explore a full range of electrification solutions based on the company’s high-efficiency inverter heat pumps. Equipped with Inverter Scroll Compressors, the entire LG Inverter Heat Pump lineup (all capacities) has earned ENERGY STAR® certification. The latest LG Inverter Heat Pumps, customized for the North American residential market – where single-family houses with high ceilings are common – deliver powerful, efficient and reliable cooling and heating. These versatile solutions also utilize embedded communication kits to ensure seamless compatibility with multiple types of indoor units including A-Coils and Furnace systems. The newly introduced LG Inverter Heat Pump Water Heater leverages the company’s DUAL Inverter Heat Pump technology to achieve maximum efficiency and offers convenient smart control via integration with the intuitive ThinQ app.
Additionally, visitors to the LG booth can check out the award-winning LG Residential Cold Climate Heat Pump. This innovative product, which received the 2025 AHR Innovation Award in the Sustainable Solutions category, is both ENERGY STAR® and COLD CLIMATE ENERGY STAR® certified. Designed specifically for colder regions, LG’s heat pump employs an upgraded refrigerant circuit and powerful compressor that enable effective operation in temperatures as low as negative 35 degrees Celsius (negative 31 degrees Fahrenheit). It also provides the Low Heating feature, which prevents pipes from freezing in icy weather conditions by maintaining a temperature of approximately 10 degrees Celsius (50 degrees Fahrenheit). The cutting-edge heat pump was developed in collaboration with the LG-led Global Heat Pump Consortium.
For commercial facilities, the upgraded Multi V i Variable Refrigerant Flow (VRF) solution incorporates a larger heat exchanger for a more powerful performance. Ideal for customers seeking to reduce their carbon footprint, LG’s intelligent VRF is a precision multi-zone temperature control solution that uses R32 refrigerant, which has a low Global Warming Potential (GWP) of 675. As well as being compliant with restrictions on refrigerant usage that have recently come into force,* the Multi V i implements advanced safety systems, including refrigerant leak prevention measure, and offers installation flexibility through its highly adaptable design.
One of the world’s leading providers of chillers, LG is introducing the Oil-Free Inverter Centrifugal Chiller at AHR Expo 2025. This impressive solution combines the company’s latest advancements in chiller technologies and thermal management systems. Applying LG’s state-of-the-art magnetic bearing technology, LeviTech, the new Centrifugal Chiller presents improved overall energy efficiency while also enhancing part-load efficiency through the inverter system. Furthermore, the Centrifugal Chiller provides a reliable supply of chilled water with support from LG’s bearing protection and fast recovery features. Demonstrating LG’s commitment to staying ahead of changes to international refrigerant regulations, the new model is available in variants employing low-GWP refrigerants such as R513A, R1233zd and R1234ze.
Located next to the HVAC booth, the Component Solutions booth highlights LG’s new lineup of compressors and motors. The company’s Scroll Compressor lineup has been expanded to target both the commercial and residential HVAC markets. By implementing innovative scroll compressor design and developing high-efficiency motors and advanced core technologies, LG continues its efforts to ensure the quality and safety of its solutions.
Moreover, the company is unveiling its comprehensive lineup of compressors for Cold Climate Heat Pumps (CCHP) at this year’s AHR Expo. LG has been working tirelessly with various HVAC manufacturers to produce advanced CCHP compressors and has participated in the U.S. Department of Energy’s Cold Climate Heat Pump Technology Challenge, where it showcased the exceptional capabilities and quality of its specialized heat pumps and compressor technology.
LG’s Component Solutions business will continue to invest in strengthening strategic relationships with major HVAC manufacturers. Through the continuous introduction of innovative technologies that anticipate market shifts, LG aims to reinforce its position as the industry leader in HVAC components.
“The LG HVAC solutions displayed at AHR Expo 2025 underscore our firm commitment to innovation, and to leading the industry’s transition toward decarbonization and electrification,” said James Lee, president of the LG ES Company. “As a leading global brand, we remain dedicated to delivering efficient and sustainable HVAC technologies and solutions tailored to diverse customer needs and environments.”
LG welcomes AHR attendees to experience its innovative HVAC technologies first-hand by visiting booth #6643 in the Orange County Convention Center.
* As of January 1, 2025, certain technologies can no longer use high global warming potential (GWP) hydrofluorocarbons (HFCs) or HFC blends. Prohibitions apply to the manufacture, distribution, sale, installation, import and export of products containing restricted HFCs and on the installation of new systems that use restricted HFCs.
With Immersive Sound, Versatile LG TV Integration and Enhanced Features,
LG Provides Elevated Audio Experience With Latest Soundbars
SEOUL, Dec. 19, 2023 — LG Electronics (LG) unveils its 2024 soundbar lineup, including the S95TR, SG10TY and S70TY models. Crafted to seamlessly complement LG TVs, these soundbars promise an elevated home cinema experience through their robust sound quality, well-rounded features and sophisticated designs.
Creating an enhanced synergy between the soundbar and TV, the elevated audio quality of LG’s newest soundbar models enriches the home entertainment experience with a heightened sense of immersion and greater convenience. When paired with WOW Orchestra, the soundbar and LG TV harness the full potential of their audio channels, creating an unrivaled audio experience with an enlarged soundstage and improved depth and height. The ideal choice for a surround sound experience, LG’s new soundbars deliver the superior quality of Dolby Atmos, driven by the advanced technology of DTS:X.
WOWCAST takes audio excellence a step further, allowing the S95TR and SG10TY models to connect wirelessly to LG TVs, ensuring superior sound without any compromise, even when playing Dolby Atmos audio. All three new soundbar models feature the WOW interface, an intuitive and user-friendly method to effortlessly manage soundbar settings and share sound modes with the TV.
At the forefront of LG’s new soundbar lineup is the premium S95TR model, delivering an impressive 810W output and captivating surround sound through its 15 channels. The S95TR boasts five up-firing channels, including the industry’s first center up-firing speaker, creating an unparalleled three-dimensional audio experience with enhanced clarity and an expanded soundstage. Moreover, the angle of the center up-firing speaker ensures a seamless audio-visual experience with precise elevation to the TV screen’s level.
The S95TR features improved tweeters for clear and precise audio, while also incorporating a passive radiator to enrich bass sounds and optimize the overall balance between the soundbar and the subwoofer. Notably, viewing quality is further strengthened in the S95TR model, designed with a matte color palette, materials and finish to effectively reduce reflections.
The SG10TY, another new LG soundbar, serves as the perfect audio and visual companion to LG’s premium OLED TVs. WOW Orchestra, WOW Interface, and WOWCAST enable the SG10TY model to seamlessly integrate with LG OLED TVs, completing the viewing experience for a greater sense of immersion. Remarkably, connecting WOWCAST to the SG10TY model and an LG premium OLED TV creates a wireless home entertainment experience with no visible cables between the screen and the soundbar. This Wi-Fi enabled soundbar provides a flawless listening experience with a high-fidelity audio quality for listeners to enjoy their favorite tracks on music streaming platforms including Tidal Connect and Spotify Connect. The thoughtful design of the SG10TY flawlessly aligns with the width and frame colors of LG OLED TVs, resulting in an impeccable visual match when paired with an ultra-thin OLED TV.
LG will also roll out the S70TY soundbar model, ideal for LG QNED TVs with its simple and compact design. This model also features the industry’s first center up-firing speaker, providing sharpened voice clarity. The angled design ensures harmonious audio and visual in alignment with the TV screen’s level.
A dedicated bracket for the S70TY model* allows users to place the soundbar directly beneath the QNED TV for a refined appearance. This bracket provides a convenient solution for direct attachment, eliminating the need to drill holes in the wall during installation. The bracket allows customizable wall-mounting of the S70TY soundbar at various heights or locations, guaranteeing an aesthetically ideal setup, great convenience and an optimal sound experience.
LG Triple Level Spatial Sound technology applies channel analysis through a 3D engine to mesmerize listeners with lifelike sound and a compelling sense of space. What’s more, LG AI Room Calibration – a feature praised by both consumers and experts for its audio enhancement – rapidly analyzes the environment of a room and adjusts the settings, enhancing the audio to harmonize with the room’s acoustics. New for 2024, the AI Room Calibration extends its capability to calibrate the audio of rear surround speakers, expanding audio immersion and offering more flexibility for installation.
In 2024, LG also plans to introduce new editions of speakers and earbuds to the global market. Despite its compact design, the most recent XO2 model offers the authentic, omnidirectional audio of the LG XBOOM 360 speaker. Featuring a distinctive conical-cylindrical design, it radiates sound in all directions, ensuring consistent, high-quality audio enjoyment for everyone in the listening space. Its compact dimensions, along with 20-hour battery life and IP55 rating, increase its portability and versatility. The most recent XBOOM 360 speaker boasts unique 360-degree mood lighting using audio reflectors, presenting a new lighting design that emanates a sense of openness and diffusion.
LG TONE Free earbuds continue to be ideal for an on-the-go option with user-centric features and a comfortable fit. The latest T90S model offers balanced sound, improved Dolby Head Tracking and refined Adaptive ANC. Additionally, the T90S supports Plug & Wireless, allowing users to enjoy their favorite shows, movies and music on non-Bluetooth devices by using the charging case as a Bluetooth transmitter.
“LG has always been committed to delivering unmatched audio-visual experiences with superior quality, all to bring a better life to our valued customers,” said Lee Jeong-seok, head of LG Home Entertainment Company’s audio business. “We remain dedicated to providing immersive home entertainment experiences through LG’s premium soundbar products, ensuring our customers enjoy the very best with further enhanced surround sound optimized for LG OLED TVs and LG QNED TVs.”
LG’s latest innovations and technologies for home entertainment will be on show during CES 2024 from January 9-12 at the company’s booth (#16008, Central Hall, Las Vegas Convention Center). To keep up with all of LG’s exciting announcements at CES, follow #LGCES2024 on social media.
* This dedicated bracket for the S70TY model is available for separate purchase.
Company’s AI Provides Personalized Experiences that
Transform and Enrich Everyday Life, Making You Feel Understood
LAS VEGAS, Jan. 7, 2025 — LG Electronics (LG) is showcasing its latest innovations powered by AI at CES® 2025. Themed “Life’s Good 24/7 with Affectionate Intelligence,” LG’s booth at the Las Vegas Convention Center illustrates how the company is providing incredible convenience and new customer experiences by seamlessly integrating AI into everyday life.
At the entrance of the booth, LG’s theme comes to life with the dynamic and immersive Brand Façade: a massive semi-circular display featuring LG Kinetic LED Media Art. LG offers its customizable Kinetic LED products as part of a total solution for customers, providing everything from the initial design to post-installation services. The company’s innovative displays deliver exceptional, multisensory experiences with stunning picture quality and the ability to perform elegant kinetic movements in sync with video and audio content.
LG’s booth at CES 2025 is divided into distinct zones representing morning, noon, afternoon, evening and night, all grounded in LG’s pursuit of “Space-as-a-Service” to expand the horizons of living spaces. Each area demonstrates how LG’s AI-powered innovations can enrich people’s daily routines. Visitors will experience firsthand how LG’s intelligent home appliances, smart living solutions and cutting-edge technologies combine to create around-the-clock comfort, convenience and connection.
A Morning with LG AI
The Rise & Shine (LG AI Home) zone showcases LG’s vision for a seamless start to the day, enabled by LG’s Affectionate Intelligence and On-device AI Hub. Visitors can explore an Intelligent Home that understands and adapts to their needs, offering proactive solutions to make each day smoother, and a personalized living environment that is both safe and hyper-connected. Visitors can witness innovations like face and voice recognition in the bedroom, which provide personalized content and wellness insights based on sleep patterns. The technologies even adapts to user’s routines thanks to automatic situational recognition and offers easy-to-digest data and insight with On-device AI hub, where sensitive information is securely protected by LG Shield.
The Connect & Cruise (Car-Commercial) zone focuses on LG’s AI-driven mobility and commercial innovations for life on the move. Here, visitors can experience AI-based in-cabin sensing solution, Vision AI mobility concept that is designed to bring greater safety, convenience and hyper-personalization to the future mobility experience.
Noon – the Perfect Time for Work and Play
The Work & Create (Intelligent Office) zone exemplifies AI’s ability to transform work into a smarter, more streamlined experience. Visitors can get hands-on experience with LG gram Pro 2-in-1, while experts demonstrate how to maximize AI capabilities using the LG CreateBoard. This presentation highlights the simplicity of generating document-based AI insights and leveraging AI-driven system controls.
The Gear up & Game (Gaming Playground) zone is an AI-optimized environment where visitors will discover an unparalleled gaming experience. LG’s ThinQ ON, which can connect with a variety of IoT sensors and devices, makes it easy to create a personalized gaming station and control mood settings with just the push of a button. Visitors can also try out the advanced webOS smart gaming monitor, including the LG UltraGear OLED Bendable Gaming Monitor.
A Rejuvenating Afternoon with Innovations that Inspire
The Inspire & Innovate (LG Labs Studio) zone is a space that inspires creativity and promotes personal well-being through innovative solutions, including AI-driven technologies. Visitors can explore personalized “ambient solutions” that align with their unique lifestyles and tastes, and see how LG’s products can transform a living space into a chic café, a relaxing retreat or a premium personal cinema. In addition, the zone also features the MX platform, which expands the definition of home solutions by creating a new type of multipurpose space. Utilizing a modular package system, it integrates LG’s innovative appliance hardware and AI technologies to transform the vehicle cabin into a flexible area.
Throughout the zone, visuals and ambient content are generated by EXAONE, LG AI Research’s multimodal AI model, creating dynamic atmospheres curated to individual preferences. Trained on 350 million license-free images, EXAONE can generate an infinite number of images with distinct moods. The images displayed in the zone are created using prompts such as “gentle breeze,” “orange summer view” and “cozy, serene atmosphere,” uniquely depicting city and countryside morning scenery in four seasons, resulting in images that cannot be found anywhere else in the world.
Curate Your Evening, Elevate Your Experience
The Curate & Elevate (Upscale Home Living) zone offers an immersive lifestyle experience that combines AI tech with enduring design and customized luxury. This exclusive space demonstrates how intelligent technology and refined aesthetics can come together to elevate every moment at home. Highlighted within this zone are innovative display products like the LG Signature OLED T. Visitors can see the transparent OLED T showcased alongside iconic clear acrylic pieces from Kartell, a renowned premium furniture brand, introducing innovative user experiences and new possibilities for space curation.
The zone also highlights the second-generation LG SIGNATURE lineup, including the brand-new LG SIGNATURE 4-Door French-Door refrigerator with a transparent OLED door panel, as well as the LG SIGNATURE Smart InstaView Over-the-Range Microwave and Slide-in Double Oven Induction Range, which pairs timeless design with state-of-the-art AI technology. With the famed Italian designer furniture company, Molteni&C, LG has crafted an exhibit that emphasizes LG SIGNATURE’s “Live Beyond” philosophy. Visitors can learn how the brand’s latest AI-equipped premium products elevate convenience and provide more personalization options than ever before.
Entering the Night area of the zone, visitors will encounter the breathtaking kinetic media chandelier; an installation that boasts 28 units of the transparent LG Signature OLED T. When closed, it highlights the elegance of transparency through synchronized video and lighting; when open, it emphasizes the sleek, thin design of transparent OLED technology. Visitors will be wowed by mesmerizing visuals, including the colorful Cloud Bloom, Aquarium and stained-glass effects; all synchronized with dynamic lighting and all enhanced by AI assistance to deliver an immersive, 360-degree experience.
The Dive & Vibe zone offers an entertaining, multisensory exploration of AI-powered sound and music. New 2025 xboom speakers on display employ advanced AI calibration technology to automatically adjust sound settings and recommend the best lighting mode according to the space and the mood of the music.
Last but not least, the Escape & Immerse zone takes CES attendees on a journey of personalized content curation and optimal viewing experiences enabled by LG’s α11 AI processor and webOS platform. The zone is divided into an entry area and an experience area, with the latter designed to showcase the capabilities of the α11 and webOS. The entry area features a dramatic man cave atmosphere, where visitors will discover a ‘secret door’ to experience AI of LG TV, where a digital guide showcases the exciting features of the technology. Highlights include the AI-powered Magic Remote, Voice ID and the cinematic picture and sound quality delivered by α11 AI processor technology.
Along with the latest smart life solutions, LG’s exhibition booth at CES 2025 showcases the company’s dedication to sustainability and corporate responsibility. Throughout the booth, visitors will find several trees symbolizing the company’s commitment to ESG. These include the Comfort Kit Tree, the Sustainable Exhibition History Tree, the Energy Tree, the Global Carbon Neutrality Tree and the Sustainable Cycle Tree, which together form a visual representation of LG’s vision for a sustainable future.
Visitors can experience LG’s latest innovations at its CES booth (#15004, Las Vegas Convention Center) from January 7-10. For more information on LG products unveiled at CES 2025, please check out the
Consolidating IVI and ADAS Systems in a Single Chip, LG’s Next-gen Controller
Sets a New Standard for the Mobility Experience
SEOUL, Jan. 3, 2024 — LG Electronics (LG), working with Qualcomm Technologies, Inc., will introduce the groundbreaking Cross Domain Controller (xDC) platform for vehicles at CES 2025. Based on Qualcomm Technologies’ Snapdragon Ride Flex System-on-Chip (SoC),* which pre-integrates Snapdragon Ride automated driving stack and computer vision, this cutting-edge solution incorporates LG’s In-Vehicle Infotainment (IVI) System and Advanced Driver Assistance System (ADAS) into a single controller. The xDC platform is set to redefine vehicle performance and elevate the mobility experience.
Due to the increasing complexity of modern vehicles, the need for a central computer that can efficiently manage diverse functionalities has become paramount. The Flex SoC addresses this need, presenting a single SoC with pre-integrated ADAS, automated driving capabilities and an open platform offering support for digital cockpit and IVI. By utilizing Qualcomm Technologies’ flexible, multifunctional chipset, LG’s xDC platform is able to rapidly process data from IVI and ADAS systems concurrently, enhancing the overall driving experience. Along with providing a more efficient mobility experience, this single-SoC innovation reduces component costs. The xDC platform also delivers the proactive assistance of “ADAS confidence view,” which combines 3D and 2D graphics to help drivers maintain focus on the road.
The platform enables drivers and front seat passengers to easily and intuitively access a wide range of information through the vehicle’s main display. This includes critical ADAS alerts, such as distance to the vehicle ahead and lane departure warnings, as well as alternative routes based on real-time traffic conditions. The system can even provide useful lifestyle information, such as promotions from frequently visited stores, to make each journey more enjoyable.
A highly-capable “all-in-one” system that can simultaneously handle multiple vehicle functions, such as navigation, safety systems and ADAS features, the new xDC is the result of close cooperation between LG and Qualcomm Technologies. The Flex SoC, which has obtained Automotive Safety Integrity Level (ASIL)-D certification – an international safety standard – contributes significantly to xDC’s ability to deliver reliable support for critical in-vehicle functions.
At CES 2025, taking place in Las Vegas from January 7-10, LG and Qualcomm Technologies will demonstrate the xDC platform in their respective private showcases. Establishing a new standard for integrated IVI and ADAS systems, the xDC platform efficiently manages and controls complex system functions and is expected to play a pivotal role in the coming software-defined vehicle era.
Looking ahead, the two companies aim to strengthen their leadership in the IVI and ADAS sectors by developing tailored solutions that meet the diverse needs of auto manufacturers. Through component integration and design optimization, LG and Qualcomm Technologies plan to deliver competitive, high-performance technologies that will help define future mobility.
“The xDC platform, which leverages the cutting-edge Snapdragon Ride Flex SoC, offers automakers a flexible solution that simplifies complex systems while enhancing the driving experience,” said Eun Seok-hyun, president of the LG Vehicle Solution Company. “Our collaboration with Qualcomm Technologies sets a new benchmark for the industry, redefining the driving experience.”
* Snapdragon and Snapdragon Ride are trademarks or registered trademarks of Qualcomm Incorporated. Snapdragon Ride and Snapdragon Ride Flex are products of Qualcomm Technologies, Inc. and/or its subsidiaries.
