BBC Iplayer not available in App Store
Having a LG OLED65CX6LA 2 FROM 2021 / software version is 04.41.45
Living in Switzerland as a English expat
BBC IPLAYER IS NOT PRESENT IN APP STORE
Please advise or help. Thx
3 answers to this question
    • By Bhanu Kumar
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
