Picross Squirell
What do you get when you combine Minesweeper, logic puzzles and pictures together? The answer is
, a fun and addictive game by PenduinBits that challenges you to solve picture puzzles (or picture crosswords, as the app name indicates) on an 8x8 grid solely using number clues that indicate how many blocks you need to fill in on a given row or column of the grid.  For $0.99, you get 384 puzzles split between Easy, Medium and Hard levels, and even a Builder feature that lets you create up to 64 more of your own custom puzzles. And with a minimum webOS requirement of only webOS 1.4.5, one purchase will work on all your webOS devices from the original Pre or Pixi to the newer Pre3 or TouchPad.
a2t.img5jGKp34FjNY
    • By Alex
      the viewer sits.
      Source:
    • By Alex
      KEY FEATURES
      LG OLED65G7V – DESIGN
      LG OLED65G7V – FEATURES
      Related:
      Related:
      VERDICT
      OVERALL SCORE
      SCORES IN DETAIL
      Read more at
        Q10 in 90 minutes
