Internet connection.
Is there any reason why I have to wait up to 5 minutes for "checking" to complete and "Internet connected". IPTV, YouTube etc will nnot load until this is complete
    • By Mandx
    • By akhil7j
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By makem
      I have a  LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
    • By NickL
      Br,
      Nick
