Hi !
I am going to buy a new LG TV, probably - which comes with WebOS (not android TV). Now, one of the features I really liked with Android TV is the ability to set ambient mode with chosen google photos albums. Is it possible also with WebOS? (without connecting any external streamer, I prefer to use the TV operating system).
Thanks!
Maor
    • By Justin Bester
    • By Ajothen
    • By atcronin
    • By Pranay Mokida
    • By Cody94549
